View DHCP statistics to manage network performance.
- In the Device Physical view, select a port.
- Select IP.
- Select the DHCP Relay tab.
- Select Graph.
- Select one or more values.
- Select the type of graph.
DHCP Stats Field Descriptions
Use the data in the following table to use the DHCP Stats tab.
Name |
Description |
NumRequests |
The number of DHCP and BootP requests on this interface. |
NumReplies |
The number of DHCP and BootP replies on this interface. |
